So about 1 out of 5 clips fail to import on the initial run, but they import after a retry.
I name my clips in name + counter format, so it's incredibly irksome when one fails because I'm left with two clips sharing the same number.
This wouldn't be so dang annoying if Apple moved to the next clip without adapting the numbers to this change.
The way it is now, if clip 003 fails, 004 will become 003. Then when I retry capturing the clip that failed, I'll have two 003 clips!
The HVX and cards have been using have seen less than 10 hours of use.
Is there a way to fix this numbering problem in FCP 7?
:badputer:
:badputer:
