fcp 5.1.4 720/25pn capture problems... HELP!
arno
When I capture my P2 Store /720/25pn the're green blocks/artifacts(?) What to do?
Arno
The footage on your P2 Store is flawless, I would bet. It's going to be a Mac hardware issue. If you can't figure out what's going wrong, try copying the footage off with someone else's computer to an external hard disk.
You mus be a senior senior senior... if it was so simply...
It's a final cut 5.1.4 problem or apple hardware memory
Well, when I see green blocks, that usually means the media is corrupt, in which case you're screwed. Could be something else, but that's been my experience.
