princethomas
I plugged my camera into the firewire on my iMac, as I always do and opened FCE. I went to capture. But this time it said something to the effect of Could not find device continue on with capture now.
Then if you try to hit capture now, I got this message:
Attempt to capture video without a device selected. Please select a video device in your capture presets and try again.
I have not figured out where "Capture Presets" is to make such a selection.
In addition, in search for that. I went to easy setup and looked there. But now I feel I have changed those settings incorrectly and I am getting a popup that says:
Unable to locate the following external devices. Apple FireWire (NTSC) 720 x 480
Your system configuration may have changed or your deck/camera may be turned off.
Check connections and click check again.
So honestly, Im not sure whats going on.
Any help here would be hot.
Thanks,
-Tom
Thanks,
-Tom
