Jonathan12uiz
FCE crashes everytime I try and log and transfer AVCHD files off my GH1
here is the console data from open to crash:
any ideas?
Code:
1/3/10 9:02:11 PM [0x0-0x39039].com.apple.FinalCutExpress[398] objc[398]: Class ProMetadataQTMDStorage is implemented in both /Applications/Final Cut Express.app/Contents/MacOS/../Frameworks/MIO.framework/Versions/A/MIO and /Applications/Final Cut Express.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader. One of the two will be used. Which one is undefined.
1/3/10 9:02:21 PM [0x0-0x39039].com.apple.FinalCutExpress[398] objc[398]: Class MIOGenericUserDefaults is implemented in both /Applications/Final Cut Express.app/Contents/MacOS/../Frameworks/MIO.framework/Versions/A/MIO and /Applications/Final Cut Express.app/Contents/PlugIns/AVCHD.RADPlug/Contents/MacOS/AVCHD. One of the two will be used. Which one is undefined.
1/3/10 9:02:21 PM [0x0-0x39039].com.apple.FinalCutExpress[398] objc[398]: Class MIOObject is implemented in both /Applications/Final Cut Express.app/Contents/MacOS/../Frameworks/MIO.framework/Versions/A/MIO and /Applications/Final Cut Express.app/Contents/PlugIns/AVCHD.RADPlug/Contents/MacOS/AVCHD. One of the two will be used. Which one is undefined.
1/3/10 9:02:21 PM [0x0-0x39039].com.apple.FinalCutExpress[398] objc[398]: Class MIOTimecode is implemented in both /Applications/Final Cut Express.app/Contents/MacOS/../Frameworks/MIO.framework/Versions/A/MIO and /Applications/Final Cut Express.app/Contents/PlugIns/P2.RADPlug/Contents/MacOS/P2. One of the two will be used. Which one is undefined.
1/3/10 9:02:21 PM [0x0-0x39039].com.apple.FinalCutExpress[398] objc[398]: Class MIOGenericUserDefaults is implemented in both /Applications/Final Cut Express.app/Contents/MacOS/../Frameworks/MIO.framework/Versions/A/MIO and /Applications/Final Cut Express.app/Contents/PlugIns/P2.RADPlug/Contents/MacOS/P2. One of the two will be used. Which one is undefined.
1/3/10 9:02:26 PM Final Cut Express[398] -[NSProgressIndicator animationDelay] is deprecated.
1/3/10 9:02:27 PM Final Cut Express[398] WARNING: Using deprecated NSTreeController internal API. Break on 'observedObject' to debug. Use of this method should be replaced by NSTreeNode/representedObject
1/3/10 9:02:32 PM com.apple.launchd.peruser.501[75] ([0x0-0x39039].com.apple.FinalCutExpress[398]) Job appears to have crashed: Floating point exception
1/3/10 9:02:32 PM ReportCrash[404] Saved crash report for Final Cut Express[398] version 4.0 (4.0) to /Users/jonathan12uiz/Library/Logs/DiagnosticReports/Final Cut Express_2010-01-03-210232_Jonathan12uiz.crash
any ideas?
