jfmason123
Using the 16:9 anamorphic conversion lense on the DVX100B, what FCE setting should be used for output to DVD (if the intended output even matters)? Under the Easy Setup menu there are four options that pertain to the word anamorphic (DV-NTSC) in this order:
1. DV-NTSC 32 kHz Anamorphic
2. DV-NTSC 32 kHz Anamorphic Basic
3. DV-NTSC Anamorphic
4. DV-NTSC Anamorphic Basic
What's the difference? Which should I use? Will the image show up squeezed if viewed on a regular 4:3 TV or will it automatically letter box?
