I suggest he use 20ga wire. He should check the UL and AWG charts and see that for chassis wiring, he can use 20ga. wire for the 7.2amps that flows through each segment. At least that's what my calculations come up with. The spec sheet says the lights use 1.5amps/meter.
16 segments x 30cm/segment = 4.8 meters. 4.8 meters x 1.5 amps = 7.2 amps.
Also check the LED strip spec to see how long of a segment you are allowed to run.
