Egg Born Son
I had a notion today while I was arranging lights for a scene on a personal project and I'm looking for a wiser head to steer me right.
I don't have a light meter (or more than a notional idea of how to use one properly) so I use my zebras exclusively to determine exposure of skin and highlights. Having two zebras on my HVX I usually set them at 70-80% and 100%. Being an HVX actually hitting 100% indoors is a pipedream, it never happens. So today while moving lights around to set up the scene, making endless adjustments trying to punch some light into the dark corners (to try and give the HVX something to see), I started wondering about what else I could use the second zebra for...which lead to me to thinking idly about DR.
I haven't really put much thought into DR before so I'm making a lot of assumptions here. But if understand correctly, the primary purpose of fill lights and background lighting is to increase the detail in the shadows. My assumption is that the theory behind this nugget of advice is that doing so reduces the physical DR of the scene. I believe my HVX is supposed to have 9-9.5 stops of DR (call it 9) and if the physical lighting can be limited to 9 stops between the brightest highlight and the darkest shadow then it will resolve the most information it is capable of. I'm guessing this is one of the purposes of a light meter.
So if all my assumptions above are in the ballpark, my question is: Can I use my zebras to accurately measure the DR?
If the zebra percentage value is accurate then it should be simple maths...100% divide by 9 stops would suggest that each ~11% should equate to 1 stop. So if I set the second zebra to 11% the entire frame should blow if all the shadows are 9 stops below the highlights (at 100%). While not forgetting to expose skin at around 70% give or take. Correct? Or is there some logarithmic vs linear scale conflict going on in this equation? Or have I simply proved that a little knowledge is a dangerous thing and all my assumptions are bunk?
Thanks in advance guys.
