My Lilliput 664 backfeeds power from the battery to the DC jack, so I could use the DC jack as a power output for a camera, even though it's technically an input. However, I'm not sure if one NP-F battery would provide enough amperage for both devices.
Here's my power set up for long tripod shoots. I wired a couple NP-F plate in parallel to a DC jack, and glued the plates back to back. I set my custom plate under my tripod and snap a couple NP-F970s on to it, then I run a DC extension cable from the output to a dummy battery to power my camera.
If I was in your shoes, I think I'd use something like this to put an NP-F battery on rails to keep the center of gravity low.
The monitor option seems to be the best method for me as far as I can tell.
Thanks for pointing out the SmallHD monitor. Is that the only monitor from SmallHD that's 7" that has a power out? I looked but there's no info on that.
Hopefully its one of their better monitors... I also considered one of Atomos monitors, but also see no info if any have power out.
That being said, would it work fine if the monitor has a two battery slot to power both devices?
The Swit battery sounds like it could be a good alternative if the monitor doesnt have a power output. Hopefully it would work in the configuration im trying to go for.
