David Zeno
Hi guys,
on another board, members are talking about external power sources for camcorders like the Canon HV20 and other models.
One thought was to use an RC hobby battery, rated at 8.4 volts ( the same as the output from the AC adapter that comes with the Canon HV20 - HV40 series ) , the DIY way of doing it would be to use this 8.4 volt RC hobby battery, hooked up to the same plug that comes off the AC adapter.
You would plug this into the camcorder, thus fooling it into thinking that an AC adapter is attached.
Has anyone done a mod like this ? , what are the downfalls of this ?
In theory, it works, but what about reality ? . One thought was - > what would happen if the voltage drops on the RC hobby battery from the original 8.4 volts..,, would the camcorder burn out ? because it is expecting a CONSTANT power input from the AC adapter, which should never change ( it shall always output a constant 8.4 volts )
Anyone done anything like this ? , it sure beats buying tiny batteries, and at about $30, you can get a very powerful hobby battery ( used in RC racing cars, boats, helicopters etc ) instead of putting out $60 on a Canon battery with 1/100th the power.
Thanks for any input gentlemen.
Dave.
Dave.
