indybones
Hi peeps....
Bit of a difficult one to categorize this question so may be in the wrong place...
And my apologies for the length of it.
Would very much like your help and opinion...
I recently read the August edition of American Cinematographer and was reading the Miami Vice section where Dion Beebe talks of photographing the film...
"On night exteriors, I tried to keep the exposure values at around 30 or 40 percent, never letting them fall below 20 percent, and kept gain at +3dB most of the time, rarely going to +6dB. It's tricky because you can look at the monitor and think the exposure looks great, and when you check the exposure values on the waveform, you find it's to low. When it's to low you get noise and often you cant see the noise on the monitors."
Couple of things really could some one please explain to me what he means by
"keeping the exposure values at around 30 or 40 percent " please.
Which got me thinking about exposure values and noise as Beebe has stated above.
I might be well off the mark with this one, was late at night when I should have been asleep...
But the HVX-200 has had lots of comments on the amount of noise it produces when it's struggling for light. As I was experimenting with the pedestal increasing and decreasing it I saw on the view finder/LCD screen that when the pedestal was in the - values you could literaly see the noise flickering alot more harshly then when it was in the + values.
So I was experimenting with a few cheapo lights yesterday, the first one was just a 60watt daylight temp, used as key at a side angle this produced a nice outline to the one side of my face, then threw the rest into dark shadow, just with this setup I couldn't really see any noise.
Then I used a 500 watt and the 60, what happened was that there was more exposure, more mid tones (because there was more light) but with this came a lot more noise and significantly a lot more blocking.
So (off the top of my head) say if we had a scale where
0= pure black and 7= pure white
and I was exposing for a face which would be about 4-5 ish, the highlights hitting at around 7 would still be in range, but the shadow levels from 0-3 would be struggling and would become noisy/blocky. So would it be advantage to increase the pedestal slightly so that there is more detail in the blacks and so that the camera wouldn't be struggling, and so that there would be less noise????
Jeeez I've just re read that sorry for the length hope all that makes sens...
And thank you for any buddha style enlightenmnet you can offer me.
Thank you
Indy
Thank you
Indy
