John Scott 3
Okay, I've searched the forums and can't seem to find an answer for my conundrum. I just want to export a Quicktime movie that still retains the 16:9 ratio that I'm applying. Currently, no matter what I do, it squishes the film. I will provide nearly all my settings so that you can know how I'm shooting and editing.
I'm shooting on a Canon XHA1 with the following settings:
Signal STD - HD
Frame Rate - 24f
Comp Out - 1080i/480i
I'm using Final Cut Pro 5.1.4 and I'm trying to export the timeline using Quicktime Conversion so that the 16:9 ratio that I have selected will remain.
My Sequence Settings are as follows:
Frame Size - 1440x1080 (HD 16:9)
Pixel Aspect Ratio - 1440x1080
Anamorphic 16:9 - Selected
Now, I've tried every single setting combination (exaggerating, but nearly all) that I could find in Quicktime Conversion in order to maintain the 16:9 aspect ratio, but it seems that Quicktime wants to squish the 16:9 to 4:3 and that doesn't work for me at all. I've also tried to maintain the aspect ratio by clicking on the "Preserve Aspect Ratio Using: Letterbox." It Didn't work. I use the following settings:
Compression: H.264
Quality: High
As for the size settings, I've pretty much tried everything but it always squishes the image.
I've read some forums about creating a new sequence or something, but that didn't work either. I'm not trying to drop it into iDVD or anything, I just want to export a 16:9 quicktime file so that I can upload it to my website in order to show people.
Is this an issue that others have encountered? I'd really love some help. I figured since the first thing everyone gives me jabs about was my squished films, I would ask how to fix it.
THANKS SO MUCH, guys (and/or Gals)
[EDIT] - I also wanted to point out that when I use Quicktime Conversion to export stills, it does the same thing. Squished.
Signal STD - HD
Frame Rate - 24f
Compression: H.264
Quality: High
