Exporting 16x9
I'm trying to export a smaller sized 16x9 movie compressed for web from a 1920 x 1080 timeline.
I'm using export quicktime conversion. How can I make a smaller sized 16x9 image while still retaining the aspect ratio. The retain aspect ratio box doesn't do the trick.
Everytime I try it squezes to 4x3, or is the full size 16x9.
thanks
854*480 will give you around SD resolution. 640*360 is smaller than that and 425*240 is smaller still. Is there a specific file size you are aiming for (i.e. it needs to be smaller than 200megs or something)?
-A
thanks
Just choose a "custom size" and multiply by 1.78 (16/9) or so.
So instead of choosing 320x240 say, choose Custom size, and 428x240
then it should look right. Same for any other resolutions you choose.
File > Export > Using Quicktime Conversion
Options
Size
Then there's a pulldown for various dimensions. From there you can either choose custom and use one of the many mentioned sizes already mentioned, or choose one of the standard 16:9 choices. The default one "Compressor Native" is crap, don't let it use that.
cheers.
