Export via Quicktime or Quicktime conversion?
blando3
When ever I export from FCP, I use Quicktime Conversion but I just read in another post that Export > Quicktime is better.
When I export a QT file using Export > Quicktime (DV/DVCPro NTSC) , the file is a bit stretched in Quicktime player. When I open that same file in FCP, it looks fine.
Then I tried exporting using Export > Quicktime Conversion, using the same compressor and the file opens correctly in both QT player and FCP.
Any thoughts on why the file created using Export > Quicktime would look stretched when opened in Quicktime Player but normal in FCP?
Should I just keep using Export > Quicktime Conversion?
Thanks,
Andrew
I use Export - Quicktime Movie for any full resolution copy I want to save or import into another project.
I use Export - Quicktime Conversion any time I want to convert it to another format for web or smaller reference copy.
CaptM
Anamorphic? Square/rectangle pixels?
Google if you're confused. I (personally) have NO frigging idea what the hell you are talking about. It's either one or the other. Unless of course you care to explain yourself further!!!
Damn kids!
CaptM
