Export location
super_plus
Is there anyway to set a default export location so that Premiere will save your file in the same place everytime you export. I have about 77 files I have to encode individually and they all have to be saved to a folder deeply hidden within my work's server. It's awfully time consuming having to go through and find the folder on every export.
Using Premiere Pro CS4
in CS3 as long as you dont close the program it will export to the same location as the last export as long its the same export method used. however , in CS4 it has a seperate media encoder and you can just set it up to batch encode.
