Export has out of sync audio! please help
deadby23
I'm using Premiere Cs5. When i play the video in the preview window everything is fine. Once i export it (to h.264 1080p) the audio and video become out of sync. Is this a common problem with an easy fix? Am i doing something wrong? HELP. Thanks. -Dan
I have the same problem with CS5 but it only exists with high def output to blu-ray. Everything stays in sync when output to SD dvd. If you find a solution, please share it. I have been unsuccessful thus far. Am using AVCHD. Jon
