For an amazing on-camera light check out the Comer CM-LBPS1800 LED light. I was so frustrated with inadequate light sources and invested many hours searching for the right light at the right price with a company that would stand behind it. Then, I found the Comer light. After reading many reviews about the light and even more reviews about LA Color Shop I decided to make the purchase.
I am amazed by the power this light puts out. The Comer is also fully dimmable so you control the power. If you turn up the power this light is brighter than any light I have used. At the same time, if you turn it up too much and get too close to your subject, they will see it as being very bright too - this is why it's awesome that you can easily adjust the power from zero to 100 percent. As a result you can light up a dark room or, turn it down and get intimate shots of your subjects.
The light also has a fully adjustable head and built in barn doors and diffusers and a carrying bag with strap.
What's more, LA Color shop has ALWAYS provided quick customer service. Most recently I returned an item and the refund was prompt.
If you need an exceptional light then this is the one for you.
