Hi Everyone..
How do I get the exact quality from the ex1 to blu-ray. I have tryied and tried many ways and I feel that I might be close. I have taken 3 short clips (2 min total) from the ex1 (1920x1080P 30fps) and imported into final cut via xdcam transfer. I than imported them into compressor using these settings...
File Format = mpeg 2
Stream Usage = Blueray
Video Format = HD 1920x080
Frame Rate= 29.97
Field Dominance= Progressive
Average Bit Rate = 34
Max Bit Rate = 40
Note: The difference between file sizes for the mov and the m2v file are aprox 5 - 6 megs (mov being greater)
I than open up Encore with these new settings...
Project Settings = Blu-ray
Television Standard = NTSC
Codec = MPEG-2
Dimensions = 1920x1080
Frame Rate = 29.97
Automatic Transcoding / MAx Audio/Video Bitrate = 40MBPS
The Difference...
Encore accepted both mov and m2v files. The results are that the color of both formats were not as brilliant as what I saw straight from the XDCAM (via component), Mov files looked darker than the m2v files. Ether this is not achievable or I am missing something. There is a noticeable difference between viewing the 2 formats and the ex1 connected via component to my TV. The Blueray player model that Im using is the Sony BDP 350. Just bought it. I'm also using Final Cut Studio and Adobe CS4. If I cant get this to work, than I would rather take back the blueray player, stick with SD and wait until there is a proper workflow that I can give my clients exact bluray results as my ex1 using all formats (1080, 720, frame rates, etc)
Is this possible?
1 more thing... I do not have a blurray burner, I have been burning on to DVD
Thanks all for reading : )
Frame Rate= 29.97
Max Bit Rate = 40
Codec = MPEG-2
Frame Rate = 29.97
The Difference...
Is this possible?
