After reading a dozen pages, not one person had commented on the noise beginning at 13 stops, which is pretty severe. I would have mentioned it, but it gets like Lord of the Flies over there once the drums start banging.
I missed that bit. That would make it 19 stops. Amazing. Truly amazing.You must have skipped the part about: "Don't look at image quality here... this is a dirty debayer with no black calibration, no offset correction and no processing on a special 21 stop DR Chart from DSC."
I'm just hoping for a high latitude in highlights
No sensor will give you good highlights. All respond to light linearly. All clip hard.
You must make for good highlight handling, when you shoot. Expose darker than you normally would, so that in post you have room to apply a curve to the highlights.
Unless your on-set monitor has a curve like that, it will look like you are way underexposing, but that's the solution for digital video, for all sensors.
..."next Alexa", coming soon...
