Encore DVD and Premiere Timeline
I have a project with a time line that was imported from premiere in Encore. I made changes to the original time line in Premiere and I thought that it would automatically update the time line in Encore but it did not.
I do not want to make all of the encore chapter changes by getting rid of this un-updated timeline and imprting a new one,
Any advice?
Are you using the CS3 or CS4 versions of Encore and Premiere?
If you are using the CS4 versions then you would want to dynamically link the Premiere sequence into Encore. That should carry over any changes. Every once in a while, it might take a while for Encore to notice that the sequence has been changed. You might try saving, closing the Encore project, and then opening the Encore project back up. The changes should take effect then.
Good luck!
