Encore CS5 M2t Audio problem
PaPa
Major Contributor
hey all,
I am in a rush to find a solution to this as I need to burn a bluray for a client of mine but am having a strange issue.
It's best if i just give you a screencap:
I'm exporting using the Mpeg2 Bluray option from premiere cs5, and if i open the file, it plays perfectly.
once imported into Encore CS5, it gives me this issue. For some odd reason the audio files of every file cut off a percentage too early.
Need suggestions asap. Thanks.
Is this forum a ghost town?
There must be film makers here who go through an adobe workflow, export their hd footage as mpeg 2 bluray with Dolby audio and then bringing that into adobe encore. What have you guys been doing to make this work?
I'm not a Premiere user, so I don't know what your export settings should be. Does it use Media Encoder to do the export? I would try exporting the audio and video separately if you haven't already done so. Definitely an odd scenario. How did the H.264 export turn out?
Kegan
I haven't experienced this with Encore. I would export/then import the video and the audio separately first and give that a shot.
Thanks guys, will give this a shot and let this export overnight, will try again tomorrow mornign and then update with results for anyone else encountering this issue.
UPDATE:
I re exported all my files over night and it looks like success.
Instead of exporting using the Preset : Mpeg-2 Bluray and leaving the multiplexing on ( one file with both audio and video ) I said no multiplex and this seems to have done the trick.
Thanks guys. dvxuser to the rescue once again.
