mackfilm Well-known member Nov 12, 2007 #1 Is there a way to make it so that color correction effects will not affect the black bits on the top and bottom of my DVX letterbox footage?
Z Zaus_Rockwell Member Nov 12, 2007 #2 you can always just crop it before u apply the effects. other than that, theres nothing really u can do, if the bars are on the actual video.
A Arson Well-known member Nov 12, 2007 #3 apply the CC effects to an adjustment layer with a mask that excludes the letterbox areas.
John Froton Well-known member Nov 12, 2007 #4 Also consider the order in which your effects are stacked. Changing the order will change whether or not effects are being applied within other effects.
Shooter Veteran Nov 16, 2007 #5 Apply a new Mask over the footage after apply all the effects. Match the original letterbox (mask)and all will be good. I do it all the time
