In case you don't monitor the Canopus/Grass Valley forum, Edius V4.54 was released on November 16, 2007. It is an updated that requires an existing V4.xx installation, and can be obtained from the Canopus/Grass Valley support site.
Fixed in this version (from v4.52)
- Fixed an issue where an audio channel's mapping was in a state that differed from when it was last saved
- EDIUS Watch now functions correctly
- Fixed an issue where an applied Region filter would show a solid black image, after applying an odd number of video filters to the same clip
- You can now specify a public folder on a network as a target for saving, when using the project consolidation feature
- Fixed an issue where memory was not properly released when opening WMV files
- Fixed an issue where displayed text would disappear, when re-sizing the XDSelect application window
- Inactive Direct3D-based overlay windows will now update correctly
- Fixed an issue that caused EDIUS to hang, if repeatedly mounting QuickTitler clips and timeline sequences for re-editing
- Fixed an issue where the BIN window was not able to make new title clips
- Fixed an issue that sometimes caused EDIUS to shutdown unexpectedly when saving a project, after repeatedly trimming a title effect and subsequently playing or stopping the timeline
- Waveforms of long clips are now displayed correctly
- Fixed an issue that caused EDIUS to shutdown unexpectedly when trimming clips, after adding or changing the settings of an associated transition
- Fixed an issue where EDIUS would not respond properly to forward and playback shortcut key commands
- VST plug-ins can now be deleted from the VST Plug-in management window
- Insert points for clips are now correct
- Fixed an issue that caused DV-based clips to appear blurry on D1 timelines, and D1-based clips blurry on DV timelines
- Fixed an issue that caused EDIUS to shutdown unexpectedly when adding a TitleMotion Pro title that featured a Roll or Crash effect, with more than one page of the title
- TitleMotion Pro titles will now use the correct aspect ratio, according to the EDIUS project's settings
- Fixed an issue that caused EDIUS to shutdown unexpectedly when adding TGA/TIFF files directly into a timeline
