Canopus just released a major update to Edius 4 -- this is a 89MB download:
In addition, Canopus is making the full version of Xplode Professional V4.5 available for users of Edius 4 -- this is a 408MB download:http://www.canopus.com/support/downloads/products.php
(requires login and EDIUS v4 product registration)
This update contains bug fixes and improvements, and is an official localized version. This release includes all previous updates for EDIUS v4 software.
Important Note: XDCAM and P2 functions are only supported with EDIUS Broadcast software. Grass Valley K2 GXF export support requires a new EDIUS Broadcast dongle. Please contact your reseller if you purchased an EDIUS Broadcast product prior to 11/12/2006 and require K2 GXF export support.
Improvements from the previous version (v4.03):
XDCAM HD import, editing and export support (updated XDCAM select utility)
Proxy editing of XDCAM SD and XDCAM HD content
Background transfer of P2 material with P2 Select (when the transfer is completed, registered clips on the P2 card will be relinked to clips on the hard drive)
When the In/Out points are set on the timeline, if a new clip is created on a timeline track (i.e., Creating a title on the T track), the new clip can be inserted between the In/Out points
Audio can be converted directly to 16bit/2ch when capturing from a source that has differing audio properties
Defaults can be set for Sync mode, Ripple mode, and Insert/Overwrite editing when starting new projects
Added a realtime audio "Pitch Shifter" to the Audio Filters
Destination folder and filenames can be specified before capturing video
Added further information and import/export of video and audio file formats (import AVI2 Type1, import and export *.DV files, view metadata of WAV, Ogg and AVI files)
Issues fixed in this version Include: EDIUS automatically shuts down when trimming a title clip created by Quick Titler
Problem with some fonts with Quick Titler
Field error when cancelling the HQ AVI output in a HDCAM 1080/29.97 project
Incorrect output (Save between In/Out in sequential files)
EDIUS freezes when opening the settings dialog of ProCoder Express for EDIUS during export
EDIUS not responding when analog input is enabled on a DELL Precision490 with EDIUS SP hardware
Rendering of a sequence becomes invalid when subsequently opening the Application Settings
Intermittent failure to cancel grouping
Inability to save the frame of the cursor when saving a still picture using Ctrl+T
Improved PAL-NTSC conversion and resolution scaling in ProCoder Express for EDIUS
Click here to view the readme for EDIUS v4.1
Older fixes also included:
Improvements from the previous version (v4.01):
Fixed issue with batch select (clip color was wrong)
Fixed issue with multicam (camera cut point not displayed properly)
Fixed issue with trim mode (Window layout)
Fixed issue with audio trim
Fixed issue when trimming sequence clips with negative speed
Fixed issue with changing speed of sequence clips
Fixed issue with importing projects made by EDIUS v3 or earlier
Fixed issue with QuickTitler when inputting long text
Fixed issue when trimming title clips
Fixed issue when exporting sequence still images
Fixed issue when canceling export of AVI files
Fixed issue when ungrouping clips
Fixed issue when saving still images from timeline
Fixed issue when using OpenType fonts
Official localized version for German, French, Italian, and Simplified Chinese
New features in version 4.01
Supported trimming using the mouse cursor within the Trim Mode preview monitor
Added new buttons to the Trim Mode preview monitor to select the trim point and trimming style (rolling, slip, slide, etc.)
Added feature to remove a cut point i.e., re-link divided clips (default shortcut - CTRL+DEL)
Added "Display master clip" option to the "Edit" menu, to display the current camera video in the Player window while using Multicam Mode
Changed the "Play the cursor area" and "Play around cut point" commands to loop playback automatically
Improved features in version 4.00
Fixed errors when trying to copy a folder inside the Bin window
Fixed errors when trying to open a clip that contains 0 (zero) frames
Fixed errors when trying to select a capture device while capturing on the same device
Fixed errors when trying to play around the cut point in Multicam Mode (HD), when many cut points were set and filters were applied to the clips
Fixed errors when trying to open the layout tool while using the Quick Titler
Fixed errors with EDIUS Speed Encoder for HDV when exporting an HDV1080/29.97p project
Fixed errors when scrubbing certain MPEG-2 clips
Fixed errors when scrubbing/playing back VOB files with non-consistent PTS (time stamp) information
Fixed errors in Quick Titler when importing certain still image clips
Fixed the video noise issue with the Canopus Lossless Codec, when exporting from third-party applications via Video for Windows
Fixed errors when dragging the mouse cursor from a T track to a VA track
We've now released the free, full version of Xplode Professional 4.5 for EDIUS.
Xplode Professional 4.5 for EDIUS features a large collection of high-quality transitions and DVEs that you can use in your EDIUS v4 projects. This package will install an additional folder of effects under your Transitions folder within the EDIUS Effects Palette, and a Composer folder containing keyframable DVEs under the Keyer folder.
Note: This update is a complete, full version of Xplode Professional for use with EDIUS Pro v4 and EDIUS Broadcast v4 only. It does not function with other NLE software, including previous versions of EDIUS software.
