edius realtime HD editing
ulisses
Hello,
I have a friend using finalcut for HD editing but looking for a realtime editing solution for chromakey and multi layer editing.
He saw an edius demo and told me it is full realtime even in HD (xdcam, P2)
Is that true ?
thanks,
Ulisses
I edit using a 24 720p time line mostly since i use JVCs. Using the m2ts Edius is realtime.
While Edius chromakeyer is very good. I use After effects for critical keying.
yes, I do. Depending on your CPU power, it is a good performer. If however there will be overloaded areas on the timeline, a context menu via right click can let you render only overloaded areas, in most cases this will be the fades or transitions or a multi layer portion.
I'm only using a core 2 duo set up right now. Our other 3 edit suites using edius are EVEN using lower specs. but they edit HD material on an SD timeline.
for p2 editing 720 and 1080 in realtime is easy as pie with edius.
I was doing it for a couple of years on a core duo 2.16ghz laptop with 2 gigs of ram and xp. now, i've got a quadd core laptop with 6 gigs of ram and it screams.
later,
Jason
Edius has a built in exporter that has an unbelievable amount of export options. F11 is the keyboard shortcut. It will do all of those you asked about
