Editing a DVD
dkamisat
Hi,
I was asked to edit contents on a burned DVD of a pageant. The editing part is easy (changing a lower third, switching two clips) but my problem is how to get that back to the DVD without too much trouble. The company that shot and authored the DVD went out of business a while ago so the original footage and project files are gone. I only have the burned copy to work with.
My biggest fear is that I will have to create a new DVD menu structure from scratch. The menu is pretty complicated with lots of animation and transitions. I don't have the time to try and recreate everything. Is is possible to edit the video on the DVD and get it back without having to create a new DVD project?
Thanks,
Deron
Hi,
Thanks,
Deron
The guys at the Doom9 Forums can help you with Re-authoring DVDs without having to re-do the structure. Depending on your skill level it may be quicker just to re-create everything.
What you'll want to do is rip the Mpeg file onto your PC and make your splice edit to fix whatever you want, and then try to re-inject the new VOB that you mux back into the file structure, and re-burn.
