Dxtory Premiere and x264vfw Dosn't work.
tuexnovia
Hi guys after 3 days checking codecs setting and so on, eventually I found this codec x264vfw and I used it to record few gameplay with a excellent results, I did even a Video tutorial for youtube, and at the end of the day I found that editing the videos in Premiere they basically don't work. O MY GOD I can't believe it, I found a solution of 300 dollars to use the codec in Premiere is just crazy...
Guys can you help me or tell me what can I do, because I love that codec with dxtory works really good, but when I try to edit it in Premiere I can't do it properly is like a mix in there you can't see the video properly everything is mixed and so on, and is because of the codec, because when I watch the video in media player classic is just perfect.
Can someone tell me what can I do, or if there is a solution Thanks...
If you know of another codec that works good I'll take it but I want something reasonable. Not Dxtory's codec 200Gb 5 minutes, is stupid and besides it doesn't work with premiere it let you edit the video but you can't export it.
Well any help will be grateful. THANKS.
It works perfect with other codecs...
This is what it happens with premiere editing...
And then in some part of the video you can watch it perfect. so I guess that is codecs... I'm unistalling premiere let's see if this it fix something but I don't think...
http://www.youtube.com/watch?v=A4T_fVs2iwI&feature=youtu.be
By tuexnovia at 2012-07-15
