Jim Arthurs
Jarred Land said:no... 35mm has almost 4x the resolution as 1080p.
Jarred... an interesting bit of a conversation with Brian Bonnick, VP of Technology for IMAX ...
"The smallest resolve power of neg film is about 6 microns. As a result, the limiting resolution on a 35mm negative frame is around 3700x2700 pixels. This means a maximum of 2000 lines of vertical resolution for an image with a 1.85 aspect ratio and even less for a 2.35:1 aspect ratio (1570 lines).
The resolution on a 35mm release print is much lower due to MTF generation loss in the film process. A recent paper from SMPTE journal reported that the real resolution that audience can discern in a high-quality 35mm cinema is about 1600 horizontal pixels, which translates to about 850 lines for 1:85 and less than 700 lines for 2.35. Most 35mm cinemas fair even worse than those numbers."
Here's a link to the original source, with more info...
http://www.siriusdude.com/blogger/2005/03/last-update-was-sunday.html
Regards,
Jim Arthurs
