Dvx 100BE or 100B?
jinks
Hi everybody, i'm excited to be here. I would like to upgrade from my small pany gs-150 to a dvx100...but need your help or advice. I've read so much about pal cams having better resolution than ntsc , but i noticed that the dvx100be(pal) has 25p instead of 24p(ntsc). My question is which of the two cams is going to give me a more 'film-look'? does the pal version also have the advanced 24 or 25p advanced mode just like the ntsc?
I'm still new to videography and would like to get the best bang for my buck between the two versions. I don't mind about playing back on tv since i will be editing on computer anyway... which takes me to my other question; do i degrade the pic quality in anyway if i shoot in pal and then convert to ntsc?
Thank you all for your input I appreciate it.
If you live here in NTSC land then I would get an NTSC camera. The PAL 25p looks about the same as the 24p mode on the NTSC version. But converting PAL footage to NTSC will not look as good as if you shot NTSC to begin with. Plus the NTSC version has 30p as well.
