Andrew McCarrick
Carbonite Member
I'm a little confused by this and was wondering if anybody could clear this up...
In this PDF file, http://www.visionaryforces.com/downloads/DVS-Clipster-3G-DCI-Mastering-User-Guide.pdf, on page 4 - 4 (Page after the Section 4.1.3 heading), where it says:
"Use the button on the right-hand side of the field Private Signing Key
What is this referring to by "Private Signing Key"
to select the private key file (*.pfx) that should be used to sign the extra
files of the DCP (Signing Key). For this you may have to enter a password to authenticate your usage of the private key. Afterwards the corresponding public key is detailed in the field Public Key above. This public key will be attached to the extra files and has to be used by D-Cinema players to verify the origin of
the files of a DCP."files of the DCP (Signing Key). For this you may have to enter a password to authenticate your usage of the private key. Afterwards the corresponding public key is detailed in the field Public Key above. This public key will be attached to the extra files and has to be used by D-Cinema players to verify the origin of
