DVFilm Epic I - Realtime DSLR editing
I installed Epic and it doesn´t do ANYTHING! The Icon is in the taskbar as it is supposed to be - that´s all! I chose low quality in the settings, defined the proxy-folder, then started Vegas (Pro 9.0c 64bit) and imported footage to the timeline. Bad playback as before, NO files in the proxy-folder. No EPIC plugin shows up in the plugin menue item as well (maybe that´s normal). When I click once on the taskbar icon of Epic in the timeline it says "medium offline". What´s wrong here??? ( I use Win XP x64.) I´d be grateful for your advice!
The majority of plug-ins aren't coded for 64-bit vegas, try using 32-bit vegas and see if that's your culprit.
That's right. Sorry but Vegas 9-64bit is not supported yet. You can run Epic with Vegas 9-32bit on a 64-bit system in the meantime.
