DVDA 2 update
Chenopup
http://mediasoftware.sonypictures.com/download/step2.asp?DID=519
Notable Changes/Fixes in Version 2.0a
A bug has been fixed that caused the Explorer window to lose its Favorites settings if the list was too long. Favorites are now saved in the following file: C:\Documents and Settings\\Application Data\Sony\DVD Architect\2.0\ExplorerFavorites.txt. The file is saved whenever you close the Explorer window or exit the application. You can copy the file to different computers or user accounts to migrate Favorites settings.
To see this file, you must have the Show hidden files and folders radio button selected on the View tab of the Folder Options Control Panel.
A bug has been fixed that could prevent text-only buttons from being displayed on a burned DVD when a video was used as the menu background.
A bug has been fixed that caused projects with 24p menus to fail during disc preparation.
A bug has been fixed that could cause audio to drop out when previewing files from the Media Explorer window.
Video performance has been improved during project preview.
DVD Architect software now checks your project for overly complex subtitles and menu highlight masks before preparing the disc.
A bug has been fixed that prevented still menus with audio from looping.
A bug has been fixed that incorrectly considered some menus with text and graphics as compliant. This could result in missing text, buttons, and graphics on menus.
A bug has been fixed that could cause audio to play back at an accelerated rate on some DVD players when using 24-bit PCM audio.
A bug that could cause broken or incorrect chapter links when opening a DVD Architect 1.0 project has been fixed.
A bug has been fixed that caused external monitor preferences to be discarded when using a 16:9 external monitor.
A bug has been fixed that prevented markers from being loaded from elementary video streams (.m2v) rendered in Vegas software.
A bug has been fixed that caused DVD Architect to crash when previewing or preparing a disc while the application was building peaks for an AC-3 file.
A bug that caused DVD Architect to recompress some compliant media when loading a DVD Architect 1.0 project has been fixed.
Re: DVDA 2 update
wicked.. thanks for being on the ball, just installed.
Re: DVDA 2 update
Isn't it great how Sony has stayed on top of vegas since taking it over. Everyone was al concerned about that. I wish I could say the same for another, uh, company, that, uh shall remain, uh, nameless. . . . . huh, hu, hu haaaaaaaadobiechooooooooooo!!!!!!!
Re: DVDA 2 update
I don't know that it was any buggier than any other program, Sony's just got the balls to tell you they're not perfect.
mike
Re: DVDA 2 update
I have used DVD Architect Ver. 1 now for a year. I have made over 20 titles and not once did I run into any of the above mentiond bugs. This is indeed "wicked". It is scary that a program would be released with so many problems.
The above mentioned bugs seem to me to be affecting normal program use. I have not upgraded yet and I glad I didn't. It sounds like to me the program was released un -usable.
Re: DVDA 2 update
When you upgrade, can you keep Version 1 installed? - Just in case there is a problem I would like to have the security of being able to go back and use the old and reliable version.
Re: DVDA 2 update
Thats Great! I have several projects in the works and can't take a chance on having these programs not working. All I really need are the subtitles and end actions upgrades. These two programs are so wonderful. I hope they (Sony) don't screw around to much with them and make them a pain to use like so many other programs I have had to battle with. Simple and clean.
