DVDA 2 Render Issue
Staino
I am currently working on a reel and am having problems with the disc burning process. It appears that after rendering the project out it will play fine on the computer if the project is played on the computer from the hard drive, after it is burned to a disc the menu section skips and pauses however the other movies within play fine. The disc are good, I burned other projects that play fine. I noticed that in the optimization menu that it wants to re-compress the background animations in the menu even though I render them in Vegas as MPEG 24p DVDA. I have noticed that DVDA seems to skip disc like this if the project is rendered to an MPEG using DVDA from an .avi or other file format. I think I have narrowed it done to where I dont want DVDA to convert the file but it seems to want to do so for the menu. Any suggestions?
I'm pretty sure that you cannot have a 24p mpeg file as a menu. I noticed this a while back, and since then have just been rendering the 24fps file to a 29.976fps file because DVD architect wants to re render the footage. You may want to check and see if that is your problem.
