Dvd studio Pro won't burn project??
artistiam
I'm trying to burn the project for some reason it formats the disk with the menu but it won't burn the footage and audio I try to simulate to see if it will play but it won't.
What needs to be done to simply burn the project to dvd?
Thanks!
Did you import your footage correctly? (MPG2 and Aiff) Also, double check your flow (graphic flow), are all of your arrows going correctly like you need them to? Are the menus and tracks set? Are the end jumps set? There's a lot of things that could be prohibiting you from burning.
Dontae Housley
AV Equipment Sales
tapeworksdontae@sbcglobal.net
www.tapeworkstexas.com
