What size of file i have to create in photoshop to use as a menu in dvdsp?? I tried 720x480 but i still have gray at the top and bottom. then i used 720x486 and then i had gray on the left and the right???
when you created the file in Photoshop, did you set the pixel aspect ratio? there is a preset that you can use that has the correct resolution and pixel aspect ratio. this will give you a correct image in DVDSP.
