DVD Studio Pro question: 4:3 menu, 16:9 video output
C Walker
I'm putting a demo reel together using DVD Studio Pro 4. It's an SD DVD. The menu is in 4:3, looks great. When I preview it, all the footage in in 16:9. There is one video on there in 16:9. the rest are 4:3. Any ideas here?
Can you explain it again I have no idea what you just said.
When I preview it... what is it?
The video on the menu?
Did you check your track settings? Each track should be set individually. Check the lower left track information box when you select each track. The 4:3 should be set to 4:3!!
CaptM
CaptM
Sorry for the bad explanation, 1st time I've used DSP4. Thanks for the help though.
Maybe this will explain it better...
I thought I had DSP set to 4:3, evidently I don't. I'm using the basic menu here: There's no timeline, etc. When I play the video, all of them play in 16:9, regardless if they're originally 4:3. So, apparently, It's set wrong somewhere and I'm missing it.
Gonna go explore the full interface and see what happens!
