DVD studio 3 output problem
heedicus
hello,
So I am using dvd studio 3 and I am trying to burn my dvd, sadly I have a third party dvd that DS3 wont recognize. So I go out to a .img when I mount the img it has the audio ts and vided ts folders, but I am having issues then burning that onto dvd and getting it to autoload. When I just burn the folders straight onto a dvd and try to play it I have to manually select the video ts folder (using mac dvd player). Any software solutions, or ways to get this to work?
Thanks,
Tren
Try this- Burn the entire disk image to the DVD instead of draging the folders. I use toast titanium to burn my DVD's. and after selecting DVD from the "other" menu I open the img file and drag the resulting file and drop it on the app. Burn the DVD and everything works fine.
(Also make sure to have the "first play" set in your original project file before you do your build. Otherwise the disk will not play either.)
If your external DVD burner isn't recognized by the Mac OS X disc burning framework (used in iTunes, Finder, etc.), try this:
http://www.patchburn.de/
It's free. I use this with my own LaCie burner with patched firmware (for better media compatibility -- highly recommended), and it works like a charm. It should let you use your burner directly from DVD Studio Pro, as well.
