mystico
I'm not sure if this is the correct area for this thread, but it seemed like the closest. I do wedding videos and am trying to settle on a good DVD printer with a shoestring budget. In reading other forums and online "guides," it seems the consensus on inkjet printers is that the initial product looks great and allows for more design creativity than thermal, but that the ink tends to fade more quickly than thermal. Well, I tried the Primera Signature Z1 (small, ~$130 thermal), and the results were horrible. :thumbdown It left certain areas of the disc blank and smeared others. The one time I tried to print an image, it smeared the entire thing. And this was tested with two different printer ribbons and two types of disc surface (silver shiny and white thermal printable). The silver shiny actually yielded better results than the other, which I found strange--but they were both subpar. The next up thermal printers cost $1500+.
I recently learned of a technology that is actually only 1-2 years old. It's called LightScribe. Included in some DVDRW drives, this allows you to turn over a disc after burning, and it will use the drive's laser to burn a design on the other side of the disc (http://www.lightscribe.com/). Has anyone had any experience with this?
Otherwise, what are your recommendations?
