I use verbatim Datalifeplus. They should last a really long time.
You problem might not be due to bad media but rather because you set your bitrate too high. Even though you are able to set your bitrate to 9mbps by DVD standards, you should try to make sure you are setting the target to around 8 and the maxium not to exceed 8.5
