DVD compression question
LAfilmaker
Hey everybody...I am have a real problem here with encore ver 1.0. I cut in avid xpress 4.6, compress to mpeg2 in sorenson 4.0 and from my understanding, it should not need to be compressed anymore because it is a DVD ready mpeg2 format, as specified in sorenson. For some reason, when I put it into encore DVD it wants to compress it again, I cannot burn a disc without doing that first. And the thing that really sucks about it is that encore compression SUCKS...it leaves all sorts of audio pops and sporatic freeze frames. I mean its "watchable" but come on. Has anyone ran into this and can you help me out. THanks!!
Re: DVD compression question
Is it recompressing it because the MPEG2 file size is too big, or for some other reason?
The problem sounds familiar to me.
I use to have that encofing with tmpeg. I resolved it making the compression more "standard" There´s a setting in the tmpeg which ask for the file to be standard compliance with mpeg2. Doing that i didn´t have the problem anymore.
Other thing you can try is not to choose the bigger bitrate (stay in 9000 as maximum/ adobe has troubles with 9600 (don´t ask me why...))
Encore doesn´t have to recompress again. So be patient and try to make test with little pieces of video, change the settings and see which one works.
