Dvd Arch. Help Needed Soon!
I may be way off here but I see there is a option to have it look like your windows XP theme or standard, if your using windows of course.
I found this on page 152 of the pdf manual.
There should be a small window on the right when no buttons are selected. There will be several tabs there. One of them will have something about color sets inside the tab. It will have an activated color set, an selected color set, and something else. I don't have my copy with me right now, so I could tell you exactly. Figure out which color set goes to the option where it is unselected and unactivated. Then go to one of the other tabs, I'm not sure which one, that will allow you to change the color sets. Make the one which you figured out earlier, completely transparent. That should do it. For more help, try using the help feature in the program.
