dvcprohd to motionjpeg B give colorshift?
Eljoninjo
I get a color shift when converting dvcpro hd to MotionJPEG B using the quictime conversion in final cut. Most time i can live with this but this time I think its to enoying. I know SD have an different colorspace than HD so I guess its the rec 709 to rec601.
What do you do to get HD to SD or hd to motionjpeg B conversion to look as its original?
Everything looks good in with aja set to dvcprohd 1080i but when I look at the converted motionjpeg B with pal sd widescreen setup the colors get a boost and especially the red color in skintones.
If I do the conversion with quicktime pro its looks more like the original but it doesn't get as sharp as the fcp output.
Any good suggestions?
