DVCPRO HD pixel aspect
DanHD
Because DVCPRO HD 720p is 960x720, after effects is displaying the footage as squeezed.
How do configure the settings so that the footage plays back in it's normal 16:9 ratio?
Funny, I was just going to ask the same question. This is Ditto for working with Panny 1080 footage, it does not come up properly either.
MagicCat
You should be able to set the pixel aspect ratio to 1.33 in your composition and on your footage. It should display correctly then. It should be under "interpret footage" setting for the footage and Comp settings for the comp. It may vary depending on what version of AfterFX you have.
A workaround is to put the 960x720 in a 1280x720 square pixel project and stretch the video horizontally to 1280x720.
Hope this helps,
Andy
