D doncsecz Member Oct 31, 2003 #1 if going to film, what is the proper demension to set in capturing and editing ? x ?....
G Guest Guest Oct 31, 2003 #2 Re: dv to film DV is always 720 x 480 (NTSC) or 720 x 576 (PAL), regardless of what camera you capture it on, whether it's 4:3 or 16:9, or what destination you have in mind for it. It's always 720 x 480 (or 576).
D doncsecz Member Oct 31, 2003 #3 Re: dv to film thank you...then all i should do is check the anamorphic 16x9 in the capture/sequences preference presets and I'm good to go?
Z Zoomforce Guest Oct 31, 2003 #4 Re: dv to film you might want to do a HD blowup first of the footage then goto film, that is something we are testing right now.
G Guest Guest Mar 24, 2004 #5 Re: dv to film And how did this blow up to HD work for you? And what were the associated costs?
