tommygdawg
As noted, this may seem like a dumb question, but I've started wondering something. Correct me if I'm wrong, but no matter which lens you attach to any given camera, the center of the image will always be the same, correct? IE...
APS-C 50mm on Super16
APS-C 50mm on MFT
APS-C 50mm on APS-C
APS-C 50mm on FF35
The one thing in common with all of these, is that the center of the image will be the same, correct? The only thing that changes is the amount of vignetting you'll get. So, my question is, why don't they just make all lenses with an FF35 image circle and call it good? Just plop the same lens on any camera you have, and just assume that everything is cropped by the same amount because every lens you have is an FF35 lens, does this make sense?
The other question I have is (and where my confusion comes from primarily), how do you know what size the image circle of a lens is when purchasing? This is particularly an issue when purchasing used lenses, for instance when people may just note that it's a Canon lens, and not specifically note if it was designed for APS-C sensors or full frames. The lenses are labeled based on the camera they're made for, correct? IE, if I buy a 50mm lens made for an MFT sensor, an equivalent lens on an FF35 would be approximately be approximately 25mm, correct? Or am I way off, assistance would be greatly appreciated
APS-C 50mm on MFT
APS-C 50mm on APS-C
APS-C 50mm on FF35
