K kane Member Nov 1, 2004 #1 -when capturing, i'm not having any 'drop frames'. is this okay? -when i check 'props' on the timeline, i'm removing '2332'. but when im rendering it inserts it. is this correct??
David Jimerson Administrator Staff member Nov 1, 2004 #2 Re: drop frames/pulldown??? If you're capturing at the default settings, you're fine. When you render out, you have the option of rendering with pulldown or not. It depends on what you choose as your format and template.
