downscaling 4K to 2K and to 1080P in Premiere Pro CS6: scaling issue
I just recently downloaded Philip Bloom's Canon 1DC native sample clips, from his 1DC review here:
http://philipbloom.net/2013/01/27/1dc/
Here's what I don't understand about the downscaling process in Premiere Pro CS6:
Let's say I have two sequences: one is 2K (2048x1080) and the other is 1080p (1920x1080)
If 2K is only 6.7% bigger than 1080p (2048 being 6.7% bigger than 1920), why is it that the same original 4K clip (4096x2160) shows up at 100% scale in a 2K sequence, and 53% scale in a 1080p sequence. That doesn't make sense.
Given that 4096 is twice 2048, shouldn't a 4K clip (4096) dropped into a 2K sequence (2048) show up scaled at 50% in a 2K sequence?
Thanks in advance for any feedback / clarification.
Sorry jcs, I can't find it anywhere. I don't see it in the effects window or in the sequence settings window.
There's a "default scale to frame size" in the General Settings section, is this what you're referring to?
I did check that box, but in my 2K sequence, when I drop any 4K clip it still shows up as 100% when it should show up as 50%.
Without adjusting anything else in Premiere, when you drop a clip into the timeline, it's always set to 100% unless you have that "scale to frame size" option activated. Thus, at 1080p in the timeline, you get a 2k image that looks "zoomed in" and a 720p image that is windowboxed.
Not at a Premiere station to check on anything further, but that's the default behavior.
What you are seeing is the middle 1920x1080 of your 4K image. Scale it down and you will see that you have a lot more image that's being cropped off around the edges. It's a mistake I made one time when I made a 720p timeline and used 1080p footage. Several shots were much tighter than I remembered.
Just change the scale to 46% (from 4K to 1080p) and you will see the rest of your image!
