I have access to a professional doorway dolly that is in need of a refurb (was told it was a Peter Lisand). The dolly has a tubular steel frame with two three hole bolt down points, one centered and one opposite of the steering / push handle. It's covered with plywood and has side lugs to add width extending wings.
There are two pneumatic tires at each corner, and most of the ball bearings are fouled, so 16 new bearing will be needed. No big deal there.
There is a cast aluminum post with a 100mm bowl that has a three hole bolt down pattern, but it's only about 2 1/2 feet tall, which puts the camera only at mid body. Is this normal? Do I extend the post or add a 3' jib to it? Also, is there a standard seat that could be added to the center mount? A cut down barstool would work, but would be hard on the cameraman's back.
Thanks in advance...
Bob
Bob
