All,
I have a used doorway dolly that I am going to refurb for a friend and use myself. We are told it is a Peter Lisand dolly, but doing the normal Yahoo and Google searches and looking at the Lisand website (www.peterlisand.com) doesn't show any photos of the dolly properly set up.
The dolly has box frame construction with a non-slip plywood top. It has 2 pneumatic tires at each corner and an Ackerman steering system with a handle that is too short (it will be lengthened). For mounting accessories it has two sets of through holes for bolting down an Elemack style mount (similar to the one shown below). One set of holes is dead center and the other is on the edge opposite from the steering wheels. It has a 14 inch riser that has a Elemack mount on top and a 6" tall Elemack to 100mm bowl adapter. Dropping a tripod head and camera on the riser assembly puts the camera at navel level. It has no provisions for a seat, but it does have lugs on the side for additional wings which we do not have.
One useful configuration is to set up a Kessler Crane with the riser assembly centered on the dolly. Of course this is not a ride along configuration.
So here is where I am seeking opinions: I have decent fabrication skills and friends who can help me with metalworking. What mods can I make that will maximize the usability of the dolly? For example, I am guessing that I should get a Matthews seat assembly and weld in a few mounts on various locations around the dolly. Does simply tossing a floor spreader and tripod on a doorway dolly work well if the dolly has an articulated seat? That seems to be the modern intended use.
I am considering adding a small crane to allow vertical movement, but to properly do that I would have to relocate the riser a few feet off of the front of the dolly and the counterweight for the crane would hang past that. Big time mechanical dollies generally use a scissor mechanism, but that is beyond my skill set to build.
Opinions sought, and pictures of doorway dolly rigs in use would be really helpful.
Bob
Bob
