I´m want to know if this will work or not before getting the cable..
If the svideo output is plugged to a svideo cable with a scart to a TV i should be seeing on the TV the comp monitor. Correct yes?
If i have a two comp monitors and on the second one i enlarge the premiere preview monitor i should see it on the TV if i select the seconde monitor as default to be seen via svideo output...
Does this make sense???
I would like to get rid of hooking up cam to firewire to tvmonitor...
Thanks for replies!
Ogrus
Thanks for replies!
Ogrus
