I know that sensor size has an effect of the 'width' of lenses, the so called crop-factor.
I also understand that, in order to get comparible shots, you put wider lenses on for instance a GH2 as opposed to a 5D to get about the same composition.
But is it exactly the same shot? No, because different lenses do have an influence on the how the shot turns out in terms of depth, depth of field, distortion, etc.
Is it possible to make the exact same shots on a GH2 as on a 5D for instance? What are the differences in composition, as a result of sensor size and thus using different lenses?
